Login
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM questions. first mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this forum and sub-forums.
Reply
LinkBack Thread Tools
Old 08-26-2007, 10:24 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
gsttuner22's Avatar
Tech Posts: 142
Photos: 15
Classifieds Rating: 1
Reputation: gsttuner22 is an unknown
about coil overs....
hey one of my friends told me if i buy coilovers for my car its gonna make my tires tuck in...is that likely to happen in our cars ?
Visit gsttuner22's homepage!  View photos of this member's car
Advertisement
To browse the forums without the advertisements above, Login/Register
Old 08-26-2007, 10:38 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Moderator
snowborder714's Avatar
Tech Posts: 4,961
Photos: 10
Classifieds Rating: 30
If the 'tuck in' you're talking about is camber, then it is possible. It all depends on how much you lower the car. I have Tein Flex coilovers and do not have a problem with my camber at all. I bought my car with coilovers on it (not sure what brand) but it was dropped over 2" at one point and yes, camber was an issue. I can tell this by the wear on the insides of the tires.
View photos of this member's car  View this member's Blog
Old 08-26-2007, 11:12 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
Tech Posts: 71
Classifieds Rating: 2
Reputation: 1512gvr4 is an unknown
as snowborder said, the tucking of the tire is caused by camber and it will happen when you lower your vehicle no matter what kind of suspension you are running. some nicer coilover kits have pillowball mounts with camber plates built into them. if you want to lower your car, just make sure you get your camber and TOE set at what you want by a professional alignment shop. a lot of people believe that camber is what causes a tire to wear out quickly, but in reality its actually the toe.
Old 08-27-2007, 01:12 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
gsttuner22's Avatar
Tech Posts: 142
Photos: 15
im getting skunk2 coil overs....can i put them on even if i have stock shocks and springs ?
Old 08-27-2007, 02:10 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
Tech Posts: 71
if the skunk2 sleeves are the same as ground control sleeves, it will use a rubber o ring in between the shock body and the sleeve itself, so that you can use it on whatever shock you have
Old 08-27-2007, 06:28 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
No_Skillz's Avatar
Tech Posts: 1,892
Photos: 18
Reputation: No_Skillz is an experienced, knowledgeable member worth listening toNo_Skillz is an experienced, knowledgeable member worth listening toNo_Skillz is an experienced, knowledgeable member worth listening toNo_Skillz is an experienced, knowledgeable member worth listening to
Keep in mind camber plates that are installed on top of the shock do not exist for 2Gs as it's suspension is different than 1Gs.
____________________________
| M | i | k | e |
Old 08-27-2007, 12:40 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Proven Member
Car: Porsche Boxster S
Tech Posts: 2,542
Photos: 10
Reputation: wret is a DSMtuners Expertwret is a DSMtuners Expertwret is a DSMtuners Expertwret is a DSMtuners Expertwret is a DSMtuners Expertwret is a DSMtuners Expertwret is a DSMtuners Expert
Quote:
Lowering on stock shocks is never recommended.
Ron
Visit wret's homepage!  View photos of this member's car
Old 08-27-2007, 12:47 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
New Member/Lurker
RUBBERBURNER's Avatar
Tech Posts: 3
Photos: 7
Reputation: RUBBERBURNER is an unknown
Indeed,don't buy them.It's a waste of money.I have them as well,but the spring are so short that the car jumps UP after a bump in the road !! There mutch to short and strong for the stock shocks
I've bought a full INTRAX set now witch i'm going to install this week ....
Visit RUBBERBURNER's homepage!  View photos of this member's car
Old 08-27-2007, 01:03 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Proven Member
Tech Posts: 35
Classifieds Rating: 0
Reputation: No Mo STi is an unknown
It all depends on what your going for. If your going for looks and a big drop go with the Eibach sportline. If your going for a stiffer more performance based spring you should go with the Eibach Pro-Kit. Then get some KYB AGX's and you'll be set. Coilovers or useless unless you plan on doing some hardcore racing/autoX
Old 08-27-2007, 02:11 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
Proven Member
Car: 90 POS Accord
Tech Posts: 111
Reputation: Boo5t_Addict is more helpful than not
As wret stated earlier, lowering springs on stock dampers isn't recommended. Why? The dampers can't handle the springs, and will wear out much, much sooner. Look around on the handling section of the forum, you'll see what others are running. The more research you do, the better off you'll be. It's better to wait and spend once on a good setup that you'll always be happy with. Sorry for rambling, just giving my $.02
Reply
Bookmarks
Thread Tools
» 2010 DSM Calendars
» DSM Mechanics Gloves
» Recent Blog Entries
Seat
by: Spdfreak
Update 4
by: Kevin TSI
Engine shots
by: Spdfreak
Best DEAL ever *Update*
by: 4Motion4g63
2.4 Liter G4CS build thread
by: Atuca
» Latest Gallery Photo
User Dsmj89
» Advertisement
» Current Poll
What will you be buying soon?
DSM Calendar - 34.78%
8 Votes
18 Votes
7 Votes
Total Votes: 23
You may not vote on this poll.
Powered by vBadvanced CMPS CMPS v3.2.1
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.1
