Lookin for a fmic jpipe(Not want buy ad)
What is the j-pip connecting too? I.e. to the stock location? or to a front mount so it wraps around the driver side to the Front mount?
The ETS J-pipe fits great and required no fan modifications, but it routes away from the stock location to the driverside.
Oh my bad I misread i thought he was trying to buy a front mount and a jpipe that all worked together. In which the one I linked him to is the cheapest Ive seen.
If its going back to stock location you can use your stock jpipe, if its still wrapping around towards the altenator side you technically can use the stock jpipe still but will have to have the pipe hit a like 80 deg bend to get to it which isnt good to have a sharp bend right there. The downwards flowing jpipes have the smoothest transition for air flow going into the licp.
Looks like this is for a FMIC setup, now is it a short route pipe style, with the IC inlet on the drivers side? If so, I know the jpipe Dejontool sells will work perfectly. Exits towards the drivers side & it sorta runs down between both rad fans. Works fine on a 2g with no clearance issues, so with a 1g you should have lots of room, as their rad/fans have more clearance.
thanks guys 4 now I hacked the up a licp just to have it bolted on. I noticed more lag with the 14b w/fmic than with the supra sidemount. The intercooler is 27x6.5x2.34. But at full boost it kicks ass. The intercooler stays cool. I cant wait to make the piping shorter
thanks
