Trouble Organizing Log-Proscan
Apeximprt2nr
620
5
Apr 20, 2005
Northern, New Jersey
Hey guys, Im using Proscan on my laptop and it works great, I love it. Only problem is that when I open up saved logs they open up weird. Instead of having Engine RPM, Timing, etc. on the top of the column and the values below them going down as the log progresses the Timing, etc is on the left and it's set up weird, making it near impossible to really read it. Any ideas as to what I can do to make it line up correctly"? Here's an example of what it looks like. *This is just a small clip of the run, I'm just using it as an example.
Code:
08-16-2007 10:12:48.879	 Engine Coolant Temperature	210.2	 deg F
08-16-2007 10:12:49.288	 Short Term Fuel Trim (Bank 1)	-0.78125	 %
08-16-2007 10:12:49.698	 Long Term Fuel Trim (Bank 1)	10.15625	 %
08-16-2007 10:12:50.113	 Engine RPM	768	 rpm
08-16-2007 10:12:50.519	 Ignition Timing Advance for #1 Cylinder	8.5	 deg
08-16-2007 10:12:50.926	 Intake Air Temperature	120.2	 deg F
08-16-2007 10:12:51.332	 Absolute Throttle Position	1.960784314	 %
08-16-2007 10:12:51.740	 Engine Coolant Temperature	210.2	 deg F
08-16-2007 10:12:52.149	 Short Term Fuel Trim (Bank 1)	0.78125	 %
08-16-2007 10:12:52.555	 Long Term Fuel Trim (Bank 1)	10.15625	 %
08-16-2007 10:12:52.968	 Engine RPM	1096	 rpm
08-16-2007 10:12:53.374	 Ignition Timing Advance for #1 Cylinder	14.5	 deg
08-16-2007 10:12:53.781	 Intake Air Temperature	118.4	 deg F
08-16-2007 10:12:54.198	 Absolute Throttle Position	12.15686275	 %
08-16-2007 10:12:54.604	 Engine Coolant Temperature	210.2	 deg F
08-16-2007 10:12:55.011	 Short Term Fuel Trim (Bank 1)	3.125	 %
08-16-2007 10:12:55.433	 Long Term Fuel Trim (Bank 1)	7.8125	 %
I would suspect that the logger was programmed poorly. I doubt there is anything you can do since the program is doing all exporting.
