joebor1776
- 49
- May 17, 2007
Cincinnati,
Ohio
Hello experts,
I tried to remove my throttlebody elbow last night to clean the throttlebody. I didn't want to mess with draining the coolant and depressurizing the fuel system to remove the whole throttlebody (it says to depressurize the fuel system in the Haynes book, but I don't understand why that's necessary). Anyway, I removed the Y bolt and the two other bolts that bolt on the elbow to the throttlebody. Turns out those four long 12mm bolts seem to hold the throttlebody onto the intake manifold? The elbow didn't want to come off, but the whole throttlebody was loose from the intake manifold at that point. Did I do something wrong?
If I go ahead an pull off the throttlebody, is coolant going to spray all over everything, or will I have time to cap off those hoses?
Thanks for your help,
Jborch
Jborch
