mach4g63t
- 402
- May 28, 2007
St. Louis,
Missouri
Okay, so, I've been doing the routine things to check the health of my GSX ... slowly but surely. I did a boost leak test today. The reason I did this is because when I boost in the top end of my gears (5.5k - 7k) I get pops through my exhaust here and there and a little bit of black smoke. I'm assuming I'm running rich and that I have a boost leak somewhere.
Well, anyway, did my boost leak and it took me a second to pin-point the leak, but here it is. It's a little screw on the throttle body that seems to be adjustable. But on my car, it's EXTREMELY rusted and stripped out. I wanted to see if I could take it out and replace it with a fresher one... Do I need to remove the whole throttle body to do this? And, what does this particular screw do? Should it leak air like crazy with only 3 psi in the pipes? I can't even imagine how much it's leaking at like 12-14 psi. Thanks.
** Edit **
BTW, the BOV is running uncirculated (that's how it was when I bought it) and the Dejon doesn't have an elbow to re-circulate. I plan to get a blow-through setup soon, but I wanted to pin-point this leak and how to remedy it first. I plan to eventually buy a FMIC and go with a blow through setup. I'm just looking for a temporary fix that isn't going to cause me to run rich in the top end of my gears. Also, since I've been adjusting that screw, my idle (which was ~1400) is now down to 1000, if it can settle. If I'm driving and take it out of gear, regardless of speed, it dies without some throttle. ALL Help appreciated.
** Edit **
