Oil?
NeilR777
Jul 26, 2007
Pipestone, Minnesota
Above the engine where the plugs plug in is some oil. The bolts are sealed, so it shouldn't be leaking, what could possibly be causing this?
If the valve cover gasket spark plug seals are shot it could leak from there. Buy a new valve cover gasket with half moon seals and the spark plug seals and see if it fixes the leaking. Also check your oil cap gasket. If they is bad it could be leaking oil into the spark plug well area. The valve cover gaskets are only like $20 shipped I think. I have bought two of them from ebay and have worked out great.
http://cgi.ebay.com/ebaymotors/93-99-MITSUBISHI-ECLIPSE-TURBO-VALVE-COVER-GASKET-4G63_W0QQcmdZViewItemQQcategoryZ33665QQihZ007QQitemZ170134765166QQrdZ1QQsspagenameZWD1V
