Rear Differential and Driveshaft came off!!! Check yours!
HustlerTalon
278
3
Sep 6, 2006
Pico Rivera, California
Has anyone else had their driveshaft come apart from the rear differential???
My car has always vibrated while cruising in the freeway at about 75-80mph...since the day I bought it...never thought much of it...2 years later, my driveshaft and rear differential came apart...The 4 bolts holding them together must have fell or something over time.
FYI: If your car vibrates at high speeds (>65mph), check the rear diff. and make sure all the 4 bolts are there or else what happened to me might happen to you...good thing I was just 2 blocks away from my house...I was only going about 15mph as I shifted to 2nd gear...the last bolt snapped!
I almost had the same thing happen to me, I was on track and at about 120 I got violent vibration, came in, though something was lose, went back out and it got worse and worse and when it started vibrating hard at 60 I gave it up, sat under the car going wwtF!!!!!! playing with stuff, yep my bolts were loose to my driveshaft.....they can come loose, so just check them every 6 months or so.
Definately checking mine in the morning, no vibrations or anything but just in case. Your pretty lucky you weren't on that 2 hour drive, that would have caused some major problems. A few years ago my friend's T/A broke the driveshaft doing 80 mph and it destroyed the underbody of the car broke the exhaust and put a hole in the floor board, and obviously broke the driveshaft. At least you were going slow.
