2.0l head on a 1.8
dyep8ball03
43
Jul 18, 2006
Wind Lake, Wisconsin
is it possible to put the 2.0l head on the 1.8l block? if it is id be doing a rebuild on the lower end and putting a 2.0l head on it.
It would probably take you less time to get a 4g64 or a G4CS (that is, if you want a 2.4)and swap it in, than try to make a 2.0 head work on a 1.8 block. Those engines are garbage.....maybe I should ask you....what is your goal with this?
