Identify plug help.
GSXspeeddemon
88
Sep 20, 2005
Austin, Texas
Which plug is the one that goes to the transmission (towrds the back, under the TB). The reason i ask is because there are two identical plugs that fit on there. So what color is the wiring to the one that goes to the tranny and where does this other identical plug go to?
Its a brownish/red color plug..........does it have a gear attached to it?
I'm not sure what other plug you're talking about, but i do know that there is another plug on the front of the tranny
I borrowed the second pic from Defiant and circled the Speed sensor plug
And yet another pic...........
Does this help:confused:
THats the plug im talking about, but there is two plugs that look like that and im not sure which one goes there.
What color are wires of the one that goes to the speed sensor?
Where does the other plug (looks like this) go to?
I know that the Speed sensor wire inside the car going to PIN 14 is white/yellow. I don't remember if it's the same color under the hood.
The speed sensor has a plastic white gear on it. This plug also has a 10mm bolt holding it in, be careful not to lose this bolt in the tranny.
I believe the other plug is the reverse light switch.....located near where the shift cables are attached to your transaxle
what is the other one for?
nevermind guys. Just for future reference the MAP sensor plug and the speed sensor plug are identical.
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
