boost problems
polen
54
May 13, 2007
springfield, Illinois
Well when i got my car a couple of months ago (95 gsx 16g turbo etc) it was running at 15psi of boost with no problems. About 3 weeks after that it would start jerking like it was losing pressure when i went over 10. I have had the psi set at 8 or 9 since it happened. It only happens if i catch boost creep and go over 10. Does this mean i have a bad boost hose or whats up?
Your problem could certainly be boost leak but, if that turns out to not be the problem, check your blow off valve. If you have an after market bov tighten the spring and then try to drive over 10psi or check your manifold pressure line going to the bov.
thanks guys will deff look into this when i get it back from the painter. Gotta fix before i sell it
