spooled_u_1st
- 331
- 16
- Aug 27, 2006
Pittsburgh,
Pennsylvania
For a 6 bolt swap, do you use a 1g coil pack if your using a 1g head?
just keep in mind if you are relocating the coil pack you will need new plug wires to fit. i made mine from a do it your self kit from pepboys, it worked great and was very easy.
so I need to make a longer harness if I want to keep the location and brackets for the 6 bolt swap?
