WOTDSM
- 167
- Dec 3, 2006
Detroit,
Michigan
Tomorrow I want to reset my oil pump sprocket becuase I am getting a horrible vibrating above 3k (bad enough to destroy 3 oil return lines in less than a month). Anyways I just want to make sure I'm not a complete n00b when I do this so all I need to do is: set #1 to TDC per the cam sprocket marks, remove timing cover, secure the timing belt to the cam sprockets to prevent play, loosen auto tensioner, line up the oil pump sprocket with the timing mark and then put everything back together right? Please correct me if I'm wrong...
Thx, Andrew
Thx, Andrew
