p0105 map sensor check engine light problem
sillyme
151
Aug 3, 2005
seattle, Washington
i ran the code it's throwing manifold absolute pressure code. i have the maf translator with a gm mass air flow sensor. the car runs good with no hiccups but i cant get this trouble code off the ecu. is the wiring wrong or is this normal? thanks
a maf sensor and a map sensor are 2 different things...did you remove the map sensor or is it busted, maybe you mounted it with a vacc line? is it leaking? LOL need more info i think.
-----bump-----
