TuRBoTaLooN
- 760
- 18
- Apr 27, 2005
Denville,
New Jersey
Ok, so for the past few weeks I have been battling the massive massive boost leaks I've had after installing my FMIC kit. Originally I held 8psi. So then I put new gaskets from the TB to the TB elbow, exhaust manifold to turbo, and turbo to the o2 housing. Tightened up all the clamps and put a few t-bolt clamps in weak areas. Some new vacuum hoses and zip ties and a new bov that was tested at over 20psi. Did another boost leak test today and it finally reached 19psi and held. After I stopped pumping air into the system, the pressure dropped faster than it should. I used the soapy water method on vacuum hoses and couplers and found nothing. I heard hissing coming from what seemed to be the catch can and by the intake manifold/injectors. The catch can (installed before I bought the car) has one vacuum hose from the valve cover to the catch can and the rest is blocked off. Shouldn't it go somewhere?
Any suggestions? The car pulls a little harder than previously with holding 8psi, but it still feels slow. Any help is appreciated guys. Thanks.
