bling5tatus
- 1,604
- 121
- Sep 23, 2005
DFW/Austin,
Texas
Ok, so I am not an expert, but I have removed my motor and it has been a major learning experience. I am now at the point of piecing everything back together. Last night I tried to put my transmission on the block... I did not have a clutch alignment tool but was told you can get it to work anyway if you just center the disc as much as you can. So... here's the question, those small hollow "pegs" on both sides of the transmission, those need to go into their respective spots on the block and a bolt needs to go through them... would the disc not being perfectly centered keep those from lining up. I mean the input shaft went in the disc, but I could not get those pegs (for lack of better term) to go in the block, even though they looked like they were lined up properly. Is there any kind of cheater trick to line up the clutch without an alignment tool? Also, I noticed that the bottom half of the bellhousing on the transmission is open and exposed when it is bolted to the motor. Is this right? Or is there something supposed to be covering that? If anyone can post a picture of what it should look like from underneath I'd greatly appreciate it. Also if there's any advice for getting the transmission on I'd enjoy that as well.
My friend does have a clutch tool, but he won't be back until this friday and I don't want to wait (I will if I have to).
