95 gsx buy
2000_svtowner
May 22, 2007
edmond, Oklahoma
ok this is my first post here, i own a 2000 lightning and just bought a 95 gsx to save some gas. my question is can i put a 98 gsx front clip on a 95 gsx? i bought the car with out a front clip and i need to replace it, please give me some feedback
Yes, and as long as you put the 98 headlights on there then it looks even better(and fits correctly). It helps to remove the whole bumper assembly when you do it though because some of the bolts are hard to reach with it still mounted on the car (if it has never been removed before.) My bet is if someone removed it before than it probably doesn't have all the hard to reach bolts. I did a 96 to 98 conversion last weekend and I couldn't be happier. If you plan to do the back it is a little bit harder. Good luck
