Help.....I bent the lil arm on the auto tentioner. Is it still ok?
dsmoverboosted
217
Feb 26, 2006
Winnipeg,
Well I screwed up. I am putting my timing belt together and when installing my brand new tb auto tentioner I bent the little tentioner arm OMG . I guess I need to lift the auto tentioner up, I put it straight on and bolted it on I guess bending the arm in the prosess.
Now I was able to bend it back into place and its completly straight now and seems solid but I want to know if its useable or not. I mean did I snap a soild piece and destroy it or just move it aside leaving it to be able to be moved back into place without ill effect?
When it comes to the tensioner, I would buy a new one. If you use it and it fails, thats a lot of extra money that it will cost you to fix whatever happens inside the head. I would suggest getting a new one just to play it safe. By bending it, you could cause it to leak or fail later down the road. Expensive mistake caught early.
Well, be thankful you caught it now instead of having the timing belt break/fall off or jump a tooth. $80 tensioner is a cheap fix if you think about it!
ya but still a burn when this one is brand new. oh well lesson learned the hard way I guess :(
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
