anmGST
- 145
- Feb 22, 2007
Waltham,
Massachusetts
I'm looking for an upgrade from my ported 14b. An not sure which one to get.The PTE is used but rebuilt after his motor blew up? The kid said ( denso 660 , 3inch exhaust , and all the stuff with a SAFC when i ran 24psi and 398WHP.)?? Possiable? Stock internals. The EVO III is also used but cheaper. I have 560 EVO injectors, 225 wally,full 3inch exhaust, Bullseye huge sidemount IC, and Injen intake. I want a daily driver and do not wish to open the motor and do head studs. The motor has 23,000 miles after it was replaced by previous owner. Thanx for any input.
I ran the HRC SMIC for abit with the evoIII & the max on that setup was about 18 psi, which was probably more like low 300 crank hp. After that you start getting knock in 3rd & 4th on a pull. Defently better then the stocker but with SMIC's you can't make the frontal surface area much larger as the space is confined & there is only so much air you can get to go through there. People say the SMIC won't support a 50 trim but something to consider is when starting to run more boost, the 50 trim will produce a cooler charge then the evoIII so depending on the level you plan to run the 50 trim may be easier on the SMIC. Now granted if you plan to run 22psi+ on the 50 trim, there no way your IC will keep up, but if you keep it down around 18psi, I think the 50 trim may be easier on your IC.
