way2slowtalon
- 147
- Oct 24, 2004
Newington,
Connecticut
Okay guys I need your help on this one big time. This is about my 97 GsX A/t with 50k miles. Here are the problems.
*Idle is 15 Vac, in Drive 11*
*15psi boost (stock), but creeps down to 12. I was running 10 without the Upper Ic Pipe, and 1g BOV. Also a/f is pegged.*
*Running stupid rich. 2nd to last green led on Autometer Phanton a/f.*
*Smells like gas all the time*
What I replaced in order.
1. Fuel Injector Lower Isolaters
2. Upper Ic Pipe (Dejon tool full)
3. 1g bov
4. Tb Gaskets (2)
5. O2 Sensor
No CEL, Idle is steady. I don't have compressed air so can't do a boost leak test. Any clue what this could be? This car is perfectly stock, with only an Injen Intake, and Upper IC Pipe. NO Mbc, or fuel pump installed.
Thanks!
3. 1g bov
4. Tb Gaskets (2)
5. O2 Sensor
Thanks!
