AWD clutch bleading
tqmx1
667
4
Jan 17, 2007
Sacramento, California
Since I picked up my 90 GSX you had to go to the floor to disingage the clutch. Our 91 FWD TSI has never had the problem. After R&Ring the engine and transmission and bleading the clutch no change:confused: so today when I was putting in the engine closeouts I took a good hard look at the slave cylinder, The banjo bolt where it attaches to the slave it is in at about a 90 degree angle(a perfect spot for a bubble of air to hange out.) You could here the air when the slave piston was bottomed out
The fix simple, A 14mm or a 9/16" box wrench crack the banjo open and depress the slave rod back into the bore. Tighten the banjo before you let go of the rod you can do it a couple of times to make sure you got it out but once should do it.:D
Also the reason the FWD cars don't have the problem the banjo is on the bottom of the slave so the odds of getting a slug of air is remote.
2G not sure if it is set up the same way
I hope that helps
Kim
