96gstdsm
- 808
- 2
- Aug 7, 2006
monroe,
New York
I decided to go with a rebuilt 6 bolt engine for my 2g eclipse. I was looking at a modified crank 7 bolt, but for another 1300 more than the 6 bolt i think it is worth the swap over for a more dependable engine. I have asked about this place before and it seems to have gotten pretty good feedback for the most part. Overbore.com i believe it is. My main question here is that i am trying to rebuild my whole car since it has 150k miles on it and make it so it should last a long time and be reliable. I am going to be rebuilding the tranny, engine, new clutch flywheel, new fuel setup and turbo, exhaust and suspension. If all this work is done by a professional engine builder and tranny place and installed by a reputable shop, this should be reliable? The turbo i am going to be running is an evo316g turbo. Are there problems that always arise with a little higher hp numbers? My goal is a complete max of 300 at the wheels, dont even know if i will be close to that with this setup. It is going to be my daily driver so it needs to perform well and for a long time! i know i wont get return on the money i invest into it, but if it lasts me a long time with few problems than that is all i could ask for.
This is the link to the engine i want to buy.
http://cgi.ebay.com/ebaymotors/MITSUBISHI-ECLIPSE-4G63T-ENGINE-1G-2-0-TURBO-GST-4G63_W0QQcmdZViewItemQQcategoryZ33615QQhashZitem160087586442QQihZ006QQitemZ160087586442\
He lists that with buy it now, i can get a choice of a few different extra options with the engine, which one should be the best or most important to have done?
Are there anything else i should have done to the engine while it is being built? Once again this is for a moderate hp daily driver.
If someone has done the 6 bolt swap, do you know besides the actual install how much it costs approximately for all the swap parts? Not including the engine and such, but like a total of the add ons needed? I have an ACT 2100 clutch now along with the ACT streetlight flywheel, i know i would need a new 6 bolt flywheel, do i need a new clutch as well?
Any other suggestions would really be helpful. I am going to be spending quite a good amount of money on this setup, so i want to make sure that i make the right choices! I am already decided, on turbo, fuel, exhaust all that, i just need to know more about the build up of an engine, not very familiar with that.
-----Ryan. Sorry for the long post.
