Midnightride
- 183
- Oct 4, 2006
Columbus,
Ohio
first, I'm leaking oil either from the oil pan or the rear main. I was under the car and noticed its leaking in the area where the scader plate it between the transfer case and the oil pan. it was hard to see if it was coming from the oil pan bolts or from the big bolt that goes through the scatter shield. Seemed to come pretty hard from the bolt but could be running from the oil pan gasket area in dip in the oil pan where the transfer case sits. It was hard to tell.
Is there a place where it will leak from if the rear main seal goes? I guess I just wanna make sure its the actualy rear main leaking and not just the oil pan. Use to be just a drop drop, now it has gotten a bit worse.
If it is the rear main, any suggestions on how to do it on a automatic 2G?
