2g Glowshift A-pillar
kain_99gs
Mar 28, 2005
McMinnville, Or., Oregon
Does anyone have experience with the a-pillar? I didn't get the gauges, as I wouldn't really trust the company for anything that important, but I picked up a dark grey 3pod a-pillar and the thing is a lot bigger in comparison to my factory a-pillar. I didn't really find much in the search. Anyone have any experience with this?
I have their gauges in two cars, work great. It should replace the stock one, and use sheet metal screws behind the pods for a better fit. If I didn't have frost bite I'd go outside and take pictures for you, looks like it's supposed to be there though. This is the best I got:
Maybe I will go out there and try fitting it in again. It is just signifigantly bigger and I don't think cutting it should be required... Here are some pictures.
Here you can see that it is longer, and a tad wider.
This picture shows that the lip that is normally closer to you is about an inch longer then stock along the entire length of the pillar.
Hey Kain, I think they did that so you could fit all of the wires and stuff behind it and not have it pushed out. It should tuck right down into your dash on the bottom and just sit over the top of your headliner.
Hey guys, just wondering if there was any update on this, how is fitment? I used to have an apillar but i sold it, because I was going to sell my car, but since I'm keeping it, I need one now, since I broke off all the clips on the stock apillar.
How does the glowshift apillar pod fit?
Did the person that created the thread ever get it to fit?
I just bought two gauges, a prosport boost and egt gauge, but I have no a pillar pod to put them in. Need input.
If someone could clear this up if its a good fitment or not, because a lotek or an autometer triple a pillar pod cost around $50-60, while a glowshift one cost around $33.
i have the glowshift pillar in my car and it fit good. I just screwed it into the the actual metal of the pillar instead of into the stock plastic cover of the pillar
