Login
Go Back   DSMtuners > DSM Forums > General > Newbie Forum
Newbie Forum Beginner/newbie/general DSM modification questions. First mods, how to run 10's when you haven't run 12's yet, any tech question that doesn't fit in another tech forum. New Members must limit their tech posts to this forum and sub-forums.
Reply
LinkBack Thread Tools
Old 02-08-2007, 08:29 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
Tech Posts: 247
Classifieds Rating: 1
Reputation: SleepingTsi94 is an unknown
LC-1 Wideband: Need info
I purchased the following for my honda when I had it. http://www.innovatemotorsports.com/x...cat=262&page=1
Well I sold that and kept this to use on my talon as the sensor was only in for a day. So pretty much brandnew. Now the questions begin. Are there any write up for installing this in a talon since it has to be wired in. When putting in a new bung I should mount this sensor behind the block on the downpipe correct? Also I going to be running a keydiver chip with a safc with 650cc injectors and a logger. Where can I pick up a good wideband gauge at a decent price. That wont cost more than the kit.
Advertisement
To browse the forums without the advertisements above, Login/Register
Old 02-08-2007, 11:07 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
New Member
Tech Posts: 16
Reputation: dcg9381 is an unknown
You sold the LC-1 and kept what?
If you have an LC-1 now, I'm assuming that you're using it as an add-in, not a replacement for your existing 02, which would be a bad thing.
The install of a wideband is generic. The instructions on the LC-1 (or any WB should say to put it in the exhaust track, typically after the turbo, on the upper half of the pipe so it doesn't get condensation.
The LC-1 can log straight to a laptop, it comes with the software.
I don't know much babout keydiver, but the chips are usually configured to work with specific output from widebands in terms of voltage. You need to find out what voltage your chip expects. The LC-1 can be reconfigured to a different voltage range.
It also has two analog outputs.. You *could* use it with a narrowband display and a different voltage range if you wanted. However, you'd need to understand that a little bit off 14.7 with a wideband is a very different indication than what a narrowband gives you.
Old 02-08-2007, 11:24 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
selmerguy's Avatar
Tech Posts: 1,626
Photos: 10
Classifieds Rating: 0
Reputation: selmerguy is pretty helpful and trustworthyselmerguy is pretty helpful and trustworthy
I have the lc-1 and xd-1 gauge. You install the bung on the side of the dp. The xd-1 gauge works great with the lc-1 since it is made by the same company. Innovate has great support aswell. Here is a link to a thread I started on widebands with a logger.
Wideband and logger with a 1g
View photos of this member's car
Old 02-09-2007, 06:23 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
New Member
Tech Posts: 16
PM me if you have install questions, but the instructions with the LC-1 are pretty good.. dont forget to calibrate it.
Reply
Bookmarks
Thread Tools
» Recent Build Entries
Night 7 - Almost There
by: knochgoon24
Night 6 - The end is near.
by: knochgoon24
Night 5
by: knochgoon24
Night 4
by: knochgoon24
Warm weather= more work done
by: badabing33a
» Recent Tech Threads
Title, Username, & Date
7 bolt rebuild ?s
by: Aproductions
Arp headstuds
by: gst fat
stock maf translator set up
by: jdunbar10
noise coming from trans
by: mattspyder
Clutch for 400HP TALON AWD
by: garputo2
» Latest Gallery Photo
User sek_phok
» Current Poll
What kind of build are you working on?
Street/Strip - 79.52%
365 Votes
Full Drag Race - 3.49%
16 Votes
Track Day/Time Trials - 4.36%
20 Votes
Full Road Race - 5.01%
23 Votes
Autocross - 6.97%
32 Votes
Dyno Queen - 0.65%
3 Votes
Total Votes: 459
You may not vote on this poll.
Powered by vBadvanced CMPS CMPS v3.2.1
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.2
