1g fwd turbo axles abs non abs any different?
wcpierson
296
2
Sep 16, 2005
Cedar Knolls, New Jersey
i need to replace my axles so i was wondering if there is any difference in the axles between an abs car and a non-abs car
Yes there is, the ABS axles have teeth on the end of them. You can use either if you are ABS. I was running around with a non ABS axle for a while. If you go with non ABS make sure to pull the fuses for the ABS, the light will be on but running around with non ABS axles can cause problems with the ABS still active.
The diference between the axles is that there is a sensor ring on the ABS axles. If you dont have ABS you can the ABS axle with no problems. The ring wont interfere with anything.
    • dhssoccer24
    • LSM
    • LSM
