Gemin Jackal
- Jan 10, 2003
Marysville,
Washington
1991 Eagle Talon TSi FWD 5spd
Just replaced VC gasket, plug gaskets and the plugs, halfcircle plug.
Car had been smoking and losing oil, originally thought the smoke was from the exhaust due to only seeing the smoke while under heavy boost, my bad.
Oil is leaking from the front side of the engine I'm guessing from the massive collection you can see in the picture. I pressure washed, compressed visible water off, let it dry and warm up. Left home and drove about a mile, simulating heavy boost conditions but no throttle mashing or tire spinning and she did very well, better in fact than I have seen her drive. Started up a hill and ran second gear from 4000-6200 with no tire spin and when I let off the throttle I felt a loss in power, or compression... a jolt I guess. big white cloud emerged from behind, pulled over, oil all over the front drivers side of the engine, and a small fire around the O2 sensor... blew that out and kept an eye on for fear of just shutting the motor down after recent boosting. No more fire let it smoke off what it could, and promptly returned home only momentarily using boost and got no more cloud but the fire had remanifested itself and was again blown out car cooled and shut off.
I don't know if it matters, or if oil could be coming from the dipstick tube but the dipstick was popped out when I first stopped and also upon returning home.
Mods on the car are intake, downpipe, and a manual boost controller currently set at it's lowest setting (since it seems to very rarely reach 12psi or so and only high in the rpm range). However when this was first installed it was, well abused considering the lack of aftermarket boost guage, mileage of the engine (137k, speedo been out for approx 300 miles, waiting on funds to deal with the oil) and lack of timingbelt being done.
If there is any more information I can offer let me know, wil lbe going to a known mechanic soon, I was just hoping to gain some insight here, thanks guys.
I apologize if this counts as a repost, I just have better information now.
Justin Neuroth
Justin Neuroth
