Raynehr
- 37
- Oct 19, 2005
Roanoke,
Virginia
I installed an E316g on my gsx over xmas here. It boosts good, but i knoticed the wastegate wasnt working properly, when i went to adjust the wastegate arm, the intake side of the turbo shifted. Literally rotated. The exhaust side is bolted to the header, so its not going anywhere, This causes a problem. The wastegate actuator is on that side of the turbo, so when it shifts it pushes the wastegate arm open causing the wastegate to not close properly, and never work right. Is this common and is there a way to fix?
