vinnybean
- 72
- Aug 12, 2006
Methuen,
Massachusetts
so i was driving home when i start coming towards a stop sign i put teh car in nuetral and coast to a stop....i push the clutch in and go to put it in gear but it wont go in. I shut the car off and put it in first (goes in all gears fine...with car off) i push teh clutch in adn try to start it but the car jerks like i have the clutch out. i end up starting the car in first and drive it home in first. This mornign i wake up and start checking some stuff out. the clutch amster cylinder wasnt empty but wasnt full. so i check leaking on the inside on the firewall where the master cylinder is. I see some leaking so i buy a new master cylinder and about half way threw this i figure i should check my slave. so i check that to find its leakin slighty to. i buy on of those and finish installing both. after bleeding the car i push the clutch in only to find it still wont go into gear. sooooo basically my question is could there be something i messed up while changin everything over or is the clutch GONE....
