sfriesen
- Oct 15, 2006
Wichita,
Kansas
I bought this 92 Talon AWD car about a week ago and it had a pretty good oil leak. I decided to pull the pan after I got under the car and saw that it had been hit from the bottom and pushed in (up). I had noticed what I thought was abnormally low oil pressure (1/4 on the stock gauge, but it NEVER moved) and wasn't sure if it was just a bad gauge. Well, the pan was pushed in far enough that you could see where it nailed the pick-up screen. There were also some remnants of orange RTV in the screen and what-not. What concerned me was this, there were some (not a LOT) metal shavings in the lower region of the pan. Some were what I'd consider "flakes", and some were pretty thick little chunks, similar in size, but thick enough that they were actualy folded over, like metal chippings.
The motor doesn't seem to make any odd noises, and compression reads 154,156,140,157 from cyl. 1-4 on the 160K motor (I assume this mileage to be correct). I first attributed the low compression on one cyl. to be a headgasket or maybe a valve not seating properly, but haven't ran leakdown or anything like that on it.
I also noticed a white pasty substance in the upper area of the pan, under where the turbo return feeds back into the pan, can anyone lead me to what that may be?
Anyhow, could this be balance shaft bearing shavings, or something worse? Like I said, motor seems to run great and I hear no knocking or grinding I would expect from a spun bearing, I'd say the low O/P was the lack of room for the pickup to get oil. I really don't have the time for a rebuild right now, as I'm down on a car to drive until it's fixed, so I wonder if there's something else on these motors that may have caused these shavings that might not be totally detrimental to the motor.
any info is greatly appreciated as I am indeed a noob, this is my first 4g63 pan-off experience, and I'm simply relying on my common mechanical knowledge to rack through this, I don't know the DSM qwerks too well yet...
