Installing B&M shifter, got a problem?
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
Everything was going fine, til the screw wont go into the top of the blue thing, the inside of the blue thing has a weird thread inside, am i doing something wrong?
i have the same shifter on my car...and it wasnt hard at all to install, so youre probably just trying too hard LOL. i cant remember specifically, but does the blue piece have threads for it to screw into? didnt it come with instructions?
IS it suppose to screw into the blue thing or slide in?
Well, go ahead and remove the shifter cable attached to the shifter lever. Pull out the lever its self and thread in the stud(bolt with threads on both sides). Place the teflon seal on the lever side then, slide(with a little bit of grease) into the blue piece that is attached to the stock shifter part. Then put a teflon seal(washer - same as the other one) on the stud and the install the nut. Then put the shifter cable on and double check all the connections and you should be gtg.
So, to answer your other question, Yes it does slide into the blue piece. Anymore questions don't be afraid to ask.
Yes, it slides through the blue part and screws into the shifter arm. From the pics, it looks like those are bearings in the end of the blue part. Don't forget the nylon washers.
yea i got it, all i had to do is use a mallet to get the screw in. i thought it was suppose to go in easy.
  • For sale 4G63 FIC 1200cc Injectors
    FIC 1200cc Injectors $350 + shipping and paypal fees* injectors were cleaned 6/23/26You must...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
