I need a 3in dp for a 2g gst
dsm4fun
36
Jun 30, 2006
modesto, California
Hey does anybody know where i can get a full 3in downpipe for my 2g fwd. I have been searching and everything starts at 2.5in and expands to 3in. Another thing is i need the downpipe to keep the cat converter because I live in california. If anyone could help i would appreciate it.:thumb:
Thanks for the link kevin but they only carry 2.5in for fwd at buschur but im checking into the hahn racecraft one. And jim thanks for your input as well.
I actually run the HAHN Super16 with their 2-1/2" O2 housing and 3" Eliminator jr. down-pipe, 3" HF cat with a modded 3" Thermal cat back.
The HAHN 3" DP starts out at 2-1/2" then TAPERS (not steps) out to 3" in about 4-6". After looking at different designs I went with the HAHN unit as the taper offers less turbulence than the step versions that are commonly available.
The other thing I liked about the HAHN unit (DP + HF cat) is that it's actually 6" longer than the OEM setup which gives you the extra length needed to cut off the "step" portion on cat-backs.
http://www.hahnracecraft.com/hahn/parts/ejr.htm
