The_EE
- 838
- 5
- Feb 25, 2006
Clinton,
Missouri
Here is the situation...
About a month ago I had a ball join fail on my car. luckily it happened in the gas station parking lot at 2mph and no on the freeway. Damaged the fender etc but I got the car back up and running. Since then, I have had a weird grinding when I hit the brakes lightly.
Here is what I have changed since then to find the cause and eliminate it.
Both lateral arms
Brakes
turned rotors
struts
springs ( lowered the car )
rear camber kit
I have tested the car for the hub bearings but the wheel had no in and out movement.
Only things I can think of now would be the lower control arm or maybe alignment causing the feeling? Alignment is going to be done Monday.
any other help would be nice because I am running out of go fast cash fixing things trying to find the solution.
Both lateral arms
Brakes
turned rotors
struts
rear camber kit
