Oil leak
IslandTSI
469
Mar 23, 2005
Charlottetown,
I noticed a bit of oil leaking out of the end of my transfer case around the u joint on the drive shaft. The only reason I noticed it is because of my exhaust being so large and the oil dripping on to it.
Am i right in thinking there is a common cause for this and maybe a recall of some sorts? If not what could it be and how easy is it to fix?
Pinion seal is in the rear end. The seal on the end of the t-case is a common place for a leak.
