Difference between T04E and T04B trims
gvillegsx
Nov 2, 2006
Gainesville, Florida
Just like the title says, this may be obvious but I dont know the difference between the T04E trim and the T04B trim on the compressor. Looking into a T3/T4 hybrid and both are offered. Thanks.
If you're referring to the compressor covers, the B is a smaller unit that encourages quick spool, but creates a warmer air intake charge than the E. Typically on a Bullseye Mitsu housing turbo, B covers are available on 50 trims, but E covers start at a 57 trim turbo. I'm not quite sure how it works for T3 turbos, so you may want to check with the individual vendor you'll be buying from.
If I had a choice between the two, I'd always pick the E cover since it facilitates a cooler air intake charge that will have less propensity to knock on pump gas.
Does that help out?
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
