apexi neo : throttle %?
neroup
Jan 27, 2006
austin, Texas
I just installed my apexi neo and want to make sure everything is in working order before I start tuning. My throttle position is 0% at idle and 100% when I barley touch the gas. Did I tap the wrong wire, or did I set up the unit wrong? My pocketlogger shows the correct throttle position. Thank you in advance.
I set the throttle position correctly (I think). Until I solve this problem should I wait on installing my 650's.
Try resetting the throttle positions and see if that changes anything, because it shouldn't read 100% until it's WOT. Go to the inital set up and set the low throttle without pressing the throttle, then set the high throttle with your foot all the way to the floor. On an opposite note mine reads 5% at idle, weird.
BUN
I do have Karman selected. I set the throttle with the up arrow, when I set the throttle position I get 0V up to 4.877V. My throttle position is like a switch, either 0% (off) or 100% (on) still. I am starting to think that I may have tapped the wrong wire. Thanks for all the help!
