90 GSX
- 322
- 2
- Jun 24, 2004
Fremont,
California
I recently installed my full exhaust and the car was running perfect, I mean it was really fast. About 3 or 4 days after I got the exhaust I started to notice the car was getting sluggish. It was moving but it was not pushing me back. Now, a week later, the car is running like crap. I can hear it slightly backfiring when I let off the gas fast or shift under boost. It feels like it's running very rich (smells like it too). The only problem I know of with the car is that the downpipe gasket is slightly blown out (but you can barely hear the leak) but that won't affect 100% throttle anyway. There are no boost leaks, plugs are fine, but I think my plug well gaskets are leaking because there was some oil on the plug boot that comes back even after I clean it. Could that be causing the sluggishness? What else could cause a gradual deterioration in power?
EDIT: I know am confident that the sluggishness and power loss is due to a weak igntion system. After replacing the coil, PT, plugs, and wires, I think that there may be a problem in the wiring or in the cas (could the cas cause a weak spark). When I spark the wire to the stud for the driver's side motor mount I am getting a yellowish spark, when I'm almost positive that I've done the test before in the past and got a crisp blue spark, that made a loud crack when it sparked.
