T4 manifold/wastegate HELP!!! *PIC
4g63telantra
454
2
Dec 10, 2004
Toronto,
Alright so I picked up a Garrett GT40 a few days back and seen that the flange on the turbo that sits onto the manifold has 2 holes.
Ill be making a custom exhaust manifold for this turbo and just wanted to know if I should run a colleter that goes from cylinder 1,2,3,4 into 1 or from what I was told is run cylinder 1&4 into one hole of turbo and 2&3 into the other.
Also as for a wastegate, If i wanted to run 18psi everyday, what spring would I have to run?
I may run dual WG set-up if I run runner 1&4 into one hole and 2&3 intot he other.
Well with a big turbo like that on that " little " boost for that turbo. The bigger wastegate your going to need. It might want to creep. Id say atleast a 40mm if you plan on running below 20 on the gt40
