help me with suggestion (Turbos)
Eclipsers208
96
Aug 4, 2006
Moorpark, California
ok so i have been researching on turbos, do you think it would be t oo much for my enigne to put and turbo on it, (i have about 122000 miles on it) or would you reccommend getting a whole new engine, if so a new engine where could i get a new one, please help
First off you can turbo your stock motor and run about 6-7 psi on it. I would recommend building it and then boosting it. Do a compression test to check and see how your motor is holding up. As far as getting an engine, I would just rebuild yours. I'm assuming you have a 420A. And 7", read the rules, we speak english here. If you can't post something helpful to the thread, don't post.
you know i love all the help but to you what is usefull i dont know motors as much as you do but as far as building my motor what should i put on it before i drop a turbo on it?? (keep in mind it has 122000, and iam starting to have this weird grinding sound when i go in reverse the shift to first the to second when i get into second and start going i can hear grinding sound, i belive it may be the clutch, as far as the compression test where can i go to get this done??) alls i as is for a little help i alawys get people saying post something usefull this is usefull to me, please help me
