cumpersgsx
- 426
- 1
- Jul 25, 2005
Detroit,
Michigan
I am in the midst of a horrible boost leak and found 2 leaks, the first one at the tb elbow to the tb. So i fixed that one and pressure tested it again. This time i found out the the tps sensor had a crazy leak as well. I did a search on the p 1400 code that i recieved during all of this mayhem and found mdp sensor. Is that the same thing as the tps or no...The tps is the on the tb right? Would a boost leak throw a code? Should i replace the sensor or try jb weld first?
