New SS Oil Feed lines to my Big 28
The ss oil lines should have a 37 degree flare to them. Once tightened they seal themselves.
The coolant lines will have 2 crush washers, one on each side of the banjo bolt. once tightened they will cruch and make the seal. Make sure they are new ones and you wont have a problem with leaks.
If you are to use pipe dope or thread sealer, you could risk getting it in your system and clogging something up.
Just dont use anything.
Thanks for the detailed info :thumb:
  • For sale 4G63 Pair of fog lights
    Pair of Fiat 500 fogs. Complete with mounting brackets and hardware. Both lens are in really...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
