4BangerV8Killer
Banned Member
- 417
- 1
- Aug 25, 2004
San Martin,
California
ok so i posted a few weeks ago asking about why my car will not boost. Last night i changed my injector O-rings...and while the fuel rail was pulled out i decided to look around a bit.....my question is where does the vaccume line for the bov lead to normally? Cause mine is tapped straight into the side on the intake manifold where a hole has been drilled.
(pic below) IS THIS OK? or does it work....could it be the cause of my ongoin boost leak
Heres a normal intake manifold and you can see how there is a screw or something in place...(which is the same on both sides)
and heres how its setup on mine
(pic below) IS THIS OK? or does it work....could it be the cause of my ongoin boost leakHeres a normal intake manifold and you can see how there is a screw or something in place...(which is the same on both sides)
..as you can see i dont have either nipples that are supposed to be there....what is the other nipple for...(the one right next to the one that the bov vaccume goes on.)
