1g timing
i look there but i dont now which one is the timing adjustment plug..is there any other pic. that i can look at..thanks
Print that article out and take it with you to your car and then look in that area and you will see the plug in reference. I used that pic and easily found it once I actually looked under the hood.
nick said:
is it same as the one you use to adjust your BISS? thanks
Yes.
For adjusting the timing you just ground the timing adjustment terminal under the hood. To set the BISS you grounf it and pin 10 on the Diagnostic Link Connector in the cabin. You must remove/detact any datalogger cable from the DLC while setting the timing since they will ground pin 10 when plugged in.
Steve
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
