97GSX88
- Nov 26, 2005
Berwyn,
Pennsylvania
Hey today I went out and purchased a Fluidyne Radiator for my 97 Eclipse (Stock one broke). I have an OBX Tubular manifold and Tial FP 41mm wastegate. I have 2 questions. First, the radiator and the wastegate are nearly touching if not touching, does this mean i cannot use this setup or will it be ok just need to watch my temp? Second, for the radiator tubing on the top of the radiator; the tubular manifold is in the way of the tube if not it is touching the tube. I am pretty sure these hoses cannot take that temperature of a exhuast manifold so does anyone have any suggestions? I thought I remembered Alien Auto having something to do with that, but their site is under construction and I cant view anything. If anyone could please help me out I would really appreciate it.
Thx
Chris
Thx
Chris
As far as your WG touching the radiator you should be fine, maybe a bent fin or two from bumps with some scratches to the WGs blue paint. I dontthink it will be a problem so long as the WG isn't dumping on the radiator
