SAFC & MisFire
The_one
117
Oct 30, 2005
denver, Colorado
Just out of curiosity, Let's say you have the following mods for your car Evo 3 turbo, exhaust system and stock fuel system, how would taken out the SAFC I or II causes misfire if you reset the ECU (unpulg the negative terminal)?
Thanks
Did you connected the two cables that need to be cut for the safc? Check all connections to the ECU.
Btw, misfire can be because of various reasons.
what type of cables
The MAF to the ECU, the SAFC takes the readings from the MAF and alters it for the ECU. Check any SAFC installation guides so you know what im talking about. Good luck.
Please define crap. Im haveing a problem like this. I baught this 91 tsi awd sunday and he was venting his BOV and im sure he used the SAFC to alter some stuff. Then when i go to monitering mode none of the gauges work on it. only gauge on monitering mode that works is battery. Ohh and now its back firing like no tomorrow.
Better?
eldiabloz13 said:
Please define crap. Im haveing a problem like this. He was venting his BOV and im sure used the SAFC to alter some stuff. Then when i go to monitering none of the gauges work on it. only gauge moniter that works is battery. Ohh and now its back firing like no tomorrow.
Engrish pleaze?
