squeeking....clutch related
paintball4fun21
168
Jun 13, 2006
onalaska, Wisconsin
ok so i start my car and its fine...then i put it into 1st and take off and it squeeks a ton...its just a high pitch long squeeking..........then if i put the clutch in it stops....after about 20sec of driving its gone. Help! cause its really annoying!! o and it mostly does it just when the cars been sitting for awhile
I just recently experienced that same problem, so I changed my alternator belt and the problem was gone.
Yea, pull on your belts and see if they're tight. If they feel loose, find the appropriate adjuster and tighten it. If that doesn't solve it, replace the belts. However, before jumping to conclusions, have a friend listen under the engine bay for you after you start it up to see if the squeel is comine from the belt side or somewhere else.
