formulav893
- 47
- Jul 5, 2006
surrey,
i just picked up a higher mileage 98 gst spyder. now the clutch on it feels different then my 96 gs spyder did. the pedal seems to feel to looser, and engage lower. some problems i have is down shifting from 5th to 4th periodicaly it wont go into 4th for a split second, no grinding or anything just wont go into it for a second. up shifting is no problem, revved it thru the gears when i had the chance and no problems up shifting. sometimes when im at a light and the clutch pedal is pressed i cant go into 4th as well unless i force it in, again no grinding or any noice of any kind whatsoever.
also noticed the clutch slips sometimes when boost kicks in, it will rev from 3k to 4k then back down to 3300ish. this happens periodically, not all the time.
so are these symptoms of a clutch going bad? ive checked for the brake fluids and its all topped up, do i still need to bleed the clutch?
i planned on changing the clutch anyways because i plan on modding the car and increasing boost, but im hoping its the clutch and not the transmission. again there are no grinds or anything and i drove the car 3300+miles across country and there was no issues whatsoever other then the down shifting, especially when comming off a highway off ramp. again this didnt happen every time but most of the time.
any help or advice is appreciated.
