fourreGsixty3
- 1,810
- 34
- Feb 4, 2006
Essex,
Connecticut
Ok, I will be getting a VRS 3" turbo-back, but with the o2 housing, and a test-pipe. I will want to keep the whole system for DD, but I want those exhaust gases to get away from the GT35R quicker for track days. So what I was thinking is when i want to go to the track I can take the piping that bolts to the test-pipe/back off, and have the guys at my family's shop weld up a 3" piece of same metal type with a flange to fit the test pipe, I willo have the custom welded pipe go back 10" more, then have a mandrel bent short 90* pice added on on the end to point the exhaust towards the ground. Here is a link to streetfire with a vid of a DSM with what I am thinking of>>>http://videos.streetfire.net/search/dsm/1/eb6f535e-79e4-4b4c-83b1-6918b2ff14cf.htm, but I would have it go a bit futher back...or just remove the test pipe and bolt that piece up to the DP. Anyone have any thoughts on this? Pros? Cons? Anything anyone has to say will be taken into consideration, also this will only be done for at the track, and for on the street I will have the entire VRS system hooked up, taking it on and off will be no problem, as for the fact that I have 4 4-point lifts. Also emissions, is not a problem, because we give so much buisness to the local emissions testing company(firestone), that we just say it will pass, and it does pass, without ever being tested.
Dustin
Dustin
