iwannaGS-T
- Mar 22, 2006
Monroe,
New York
ive researched this and cant quite seem to find the answer to my question. my gs has given me problems when i try to start it. ill turn the key and i hear a click or two and then all you hear id the starter gear spinning until i let go. does anyone know what i should do? sometimes it works the first time i try and other times it takes 5 or 6. Also when it does start theres a loud high pitched zing. so far ive replaced the starter 4 times. i tested the starter i have now and its fine the gear pops out all the way and spins fine and my flywheels teeth look ok too. i dont think the flywheel is moved any and all connections seem to be good. please help.
