snowboard4life3
- Apr 3, 2006
windham,
Maine
I have 93 tsi awd. I went out and got a jdm 6 bolt cylcone 91. so i went out and got a stage 4 clutch also.. went to put everything back together and tried to but my flywheel (clutch assembly) into my bell housing.. and it didn't fit tried for a couple hours. (i left my 7 bolt tranny in) then i lifted the motor back out and measured the flywheel and the 6 bolt flywheel is a 1/2 inch bigger then the 7 bolt.. i was wondering if anyone has ever heard a 6 bolt flywheel that is the same size as the 7 bolt flywheel.. or if someone could just give me some advice.. ir eally dont wanna spend another 700 on a tranny.. ### help thanks
You need an awd flywheel and it will work.
