xlMcMlx DsM
- 276
- 2
- Nov 7, 2005
Madison,
Wisconsin
Well, to fill you guys in, when i did my motor swap, i didnt tightend the clutch slave cylinder all the way. and a few days later, i went through a resiviour of clutch fluid. And during that time, when i drove it once or twice to see what the problem was, the clutch would engage when you barely let it up. I also realized that the boot on the clutch slave cylinder was torn, which was leaking fluid. So i went and got a new one, put it on, and bled the system for air. Well, the clutch is different from before, the part the cylinder rod pushes on is not as far to the right as it could be. Now when i push in my clutch, it have to push it about an inch further down for it to engage from when i first got the car. My question is, can i adjust the clutch pedal or something so it feels more comfortable? thanks
